Macbook A1466 820-00165 U4500 Heating Up
Instafixx
Machine had come in for SMC Issue. PPBUS was 8.17V.
Reballed the SMC and it started working. Came in again after 1 week. It has intermittent shut down issue. As if the machine gets hot and it goes off - fan goes high.
Thermal scanning shows U4500 getting got .
How to do go about it
Chip removed. Machine turns on and works. But shuts down randomly.
I plug it on charge. I get chime. it turns on and then shuts down. This will happen many times and then it will turn on randomly.
It is very random. Sometimes for 15-20 mins.
Sometimes in 1-2 minutes. But its mostly 1-2 minutess. Very rarely it stays up till 15-20 mins.
In SMC bypass shuts down fast too?
If possible, check the sensors with HWMonitor.
Just in case, try to run diagnostic mode.
Tried. It shut down during diagnostics. U2800 heating up - but very slightly. Have removed that too. Will check it for a day and let you know.
