Macbook A1466 820-00165
Instafixx
A few caps were green. replaced.
Machine not turning ON.
PP3V42 is present
PPBUS is 0V. No Shorts. Diode is .180
Removed the Fuse still no voltage there.
No Fan Spin.
Instafixx
Its all 0.1V.
Replaced it. Still the same
Diode Mode Reading
CHGR_AGATE_DIV is 2.82
PPDCIN_G3H_INRUSH .670
CHGR_SGATE_DIV 0
Instafixx
Pin 1 is 16V
Pin 2 is 0.2V
Bad? Need to change?
Replaced
PPBUS now 8.6V. But no fan spin
Q7180 Voltages now at 16.4V
R7185 After replacing
Pin 1 in 16.4V
Pin 2 is 6.4 V
All SYS PWRGD is 0V
So you are in 5s pulsing scenario.
Why is so difficult to get accurate information from you?
Check for pulse at pins 7 & 3 of U1950.
Also test if board stays on in SMC bypass mode.
