Macbook A1466 (820-3437) PPVBAT Short
Instafixx
PPVBAT_G3H_CHGR_REG is shorted. Diode Mode Readings is 0.137 after removing the fuse.
Tried Injecting Voltage but not taking any amps.
Removing Q7130 removes the short. But replacing it and the short comes back
Why do you consider 0.137 being short?
Do you know how a SCHOTTKY diode indicates???
Didn't even compare with similar working board?
Yeah, when no shottky diode is involved!
"Didn't even compare with similar working board?"
Was to complicated?
So, what basic voltages do you get on the MLB?
Didnt have a similar board. But have had issues with 820-00165 when PPBVAT was 0.140s.
Currently Q7130 is removed and fuse is removed. You want me to put it back and give you the voltages ?
Pin 1 - 3.4V
Pin 2 - GND
Pin 3 - 3.4V
Pin 4 - 2.7V
Pin 5 - 3.4V
Pin 6 - 3.2V
Pin 7 - 3.4V
Pin 8 - 3.3V
Check voltage and diode mode on SCL/SDA lines of battery bus.
Be sure R7100 is good.
You may need to reball/change SMC.
