Macbook a1707. 820-00281. no image
ipetro
no video no video on either the external or internal display.
consumption:
19.95V.
1.300A (and slowly rises)
Any history available?
What is CPU core voltage after 10-15s?
Did you check USB activity and Caps Lock LED reaction?
ipetro
PPVCCIO_S0_CPU=0.961v
PPVCC_S0_CPU=1.053v
PPVCCSA_S0_CPU=1.129v
PPVCCGT_S0_CPU=0v
PPVCC_CPU_PH1=1.055v
PPVCC_CPU_PH2=1.055v
PPVCC_CPU_PH3=1.055v
The backstory is as banal as always, I didn’t turn it on this morning. The battery is not charging (by the way)! The touchpad works. Caps lock won't turn on.
The board can't boot with CPU core stuck at 1.05V; it should drop to 0.65V aprox.
Try known good BIOS, clean ME.
ipetro
where can I get a known working BIOS file? can you help me with this? is the bios suitable xinzhizao? or can I send you my BIOS file to check?
ipetro
820-00281...LH32D.BIN
I wrote this firmware and everything worked. but doesn't see the battery. Could this be due to the BIOS or a bad battery?
You have another problem with the battery.
You've mentioned before touching BIOS that battery wasn't charging.
Be sure its data cable is OK.
Should test with known good battery.
