Macbook A1708 820-00840-A / 20V 400ma / No Post
GfilipeZ
This machine stopped working suddenly.
Like a wrote in the title, the amperage goes to 650mA and after a few seconds drops to 400mA. CPU and SSD warm a little, but nothing special.
Apparently, sound alike the Logic Board is going to boot normally. But there's no image on display; no image on external display; no backlight on display neither keyboard and no green light on "caps lock". Only trackpad clicking.
I already checked on microscope for corrosion signs, and there's no liquid damage. There's no sign of previous intervention on Logic Board or damage in any components.
Checked all voltages of page 69 (Power Aliases), and all voltages are present. The only voltages that caught my attention were the PPVCCCPU_S0G_PH1 and PPVCCCPU_S0G_PH2. Both goes up to 0.9V, but if i'm right on a normal boot the voltage should drop to 0.6V, wright?
Not good, CPU core shpuld drop (as above mentioned), when board really boots.
Test the board alone on the desk; only charger connected.
PLT_RESET_L goes high?
You can try known good BIOS.
GfilipeZ
Yes, i'm working on the desk only with the board and power supply.
I forgot to mention, that i already tried a known good bios file and IC.
PLT_RESET_L = 3.3V stable
GfilipeZ
Already tried it, but still with the same behavior.
I'm not gona loose more time with this board.
Thanks 2informaticos!
