Macbook A1708 820-00840 Buzzing Sound
Instafixx
Hi My right speaker buzzes whenever i open youtube or start playing any sound.
I tried with another speaker - but same.
The board has no corrossion as such.
J6603 - Diode Mode Reading
Pin 3/4/5/6/7/8 = .584
Pin 9/10/11 = .584
Pin 12/13/14 = .588
Instafixx
There was corossion under U6440. Removed - Cleaned - ReInstalled. Its less buzzing but its still there. Should we change it ?
Instafixx
Before Replacing the U6440 . Readings of surrounding caps.
C6447 is .947
C6440/1 is .364
C6442 is .567
C6448 is .596
C6443/4 is .412
Seems okay? Should we replace ?
If can't clearly see corroded caps, change U6440.
Once the chip is removed, check trace continuity from its pads to surrounding components.
