Macbook A1708 820-00840 No Backlight
Instafixx
Hello,
Confirmed NoB-ack Light. Display is fine - Checked on another machine - No Flexgate.
Voltage on PPVOUT_S0_LCDBKLT is 0V
Ohms Reading is keeps increasing and ultimately stops at 167.5 kOhms . Checked at C8473
Any history available?
Do you get image, only missing backlight?
Check 3V3/5V_S0SW_LCD and DP_INT_HPD voltage.
Instafixx
Thank you for guidance.
Yes i get image only Backlight missing. I can see the apple logo with a flashlight .
No history available. The board looks clean.
L7690 is a bit rusty but i get voltage there.
3V3 and 5V_S0SW is fine.
DP_INT_HPD is 3.28V
First step, check F8400.
Be sure all resistors around U8400 have correct ohm value (not to ground).
Pay atention to the resistors connected to SCL/SDA lines.
Also check voltage and diode mode to ground on these lines.
Post diode mode to ground readings at both pins of D8410.
Instafixx
Ohms Value ( Not to Ground)
F8400 1.1 Ohms
R8444 - 1.4 Ohms
R8410 - 13.4 Ohms
R8453 - 1.2 Ohms
R8452 - 1.2 Ohms
R8450 - 0.7 Ohms
R8451 - 0.7 Ohms
R8442 - 1.1 Ohms
R8445 - 0.7 Ohms
R8440 - 1.01 M Ohms
R8431 - 17 KOhms and keeps on increasing.
R8432 - 60K Ohms and keeps increasing ( Sometimes shows 3.8 M Ohms and decreases)
Diode Mode Reading (Red to Ground)
D8410
Pin 1 is .894
Pin 2 is 1.228
SCL/SDA line resistor is .557
For high value resistors, is normal to get lower readings measuring them onboard.
However, can't get short (1.2 ohm) for R8452/3.
Please, recheck their values.
Instafixx
R8444 - 0.9 Ohms
R8410 - 13.4 Ohms
R8453 - 1.34 KOhms
R8452 - 1.32 KOhms
R8450 - 0.7 Ohms
R8451 - 0.7 Ohms
R8442 - 0.9 Ohms
R8445 - 0.7 Ohms
R8440 - 1.01 M Ohms
Rechecked
"R8432 - 60K Ohms and keeps increasing ( Sometimes shows 3.8 M Ohms and decreases"
High value resistors must be measured disconnected from circuit.
Desolder one pin and check it then; is more easy to measure than out of board.
Also check all traces continuity.
