Macbook A1990 820-01041, missing PCH_RTC_RESET_L / PP3V0_G3H_RTC. 20V 600mA no charge
Paul Daniels
Super Moderator
3rd tech looking at this machine.
LD on U9801, U9850 (GPU MUX related) - replaced
LD on U7370 - replaced
LD on U1950 - replaced
So far nothing has resolve the primary issue where the machine will fire up to 20V, spike 800mA for a moment, then reduce to 600mA constant and run the fans from 'standard' speed up to 'full speed' within a few minutes.
Have gone through a rails list and it stops with PCH_RTC_RESET_L missing (0V) and likewise PP3V0_G3H_RTC missing.
Diode mode for PP3V0_G3H_RTC is ~0.6. No LD around PMIC/Calpe
No battery charge occurs but the board will run off battery.
Power on/off is achievable. Machine is not DFU/RECOVERY mode either (plugging in to an AC2 machine yields "Unable to power/use this thunderbolt device".
Paul Daniels
Super Moderator
UPDATE: U5870 had corrosion on it, replaced, got my 3V0 RTC PLATFORM_L etc all back and get all the way to ALL_SYS_PWR_GOOD, PM_PCH_PWROK and PM_PCHSYS_PWROK and everything "online" but it still doesn't boot. Still ramping the fans too.
1am, time to put it aside and try again tomorrow.
What is CPU core voltage?
It should drop until 0.65V, when board really boots.
Check U2072's I/O signals.
Paul Daniels
Super Moderator
0V on CPU core ( 1R50 ).
PLT_RST_L going to U2072 doesn't appear to go high.
I also lose CPUCORE_PROCHOT_R_L out of U7100:46, it's there for a few seconds ( 20V 800mA->600mA ) and then is asserted low (0V).
Paul Daniels
Super Moderator
All good with U4760, rails and signals being transferred one side to the other.
Might have to put this aside for a bit and look at it with fresh eyes again later.
