Vogelek23
Hi there, I have some 15" MacBook A1990 on my bench. Backlight works only when battery is discharged below 1% (screen shows flat battery). When battery is charged to the point that the computer starts up (above 1%) there is no backlight, however, the Apple logo and login screen appear when I shine the LCD panel with some external light.
What's been checked/replaced/measured (and did not do the trick):
- checked MLB inside a different chassis (known working) to exclude all peripherials,
- reballed GMUX (U9850), GMUX expander (U9801) and T2 chip - after some suggestions found on the internet,
- replaced screen with a known working one (genuine),
- replaced LVDS flex,
- replaced backlight controller (U8400),
- checked both sides lid sensors; they work correctly - when the lid is closed there is 0V on LID_OPEN_LEFT, LID_OPEN_RIGHT, IPD_LID_OPEN points, when lid is open 1.8V is present on all 3 points,
- measured EDP_BKLT_EN (3.3V present in both cases), PPVOUT_S0_LCDBKLT (55V present in both cases),
- for one moment I've got the correct backlight on login screen - I've checked both side lid sensors using an external magnets, both work correctly.
After computer restarting, the problem came back. I stuck on this now and have no idea what to do next.
