Macbook A1990 SSD Issue (2019)
Instafixx
Device came in with SSD Issue. (Original Configuration 256gb)
L9081 was shorted.
Removed that and injected voltage - SSD was heating up.
Customer approved SSD replacment. I removed all SSDs. and replaced TPS62180. Short is gone.
I applied direct transplant method.
Took out a A2179 with a 2 NAND configuration of 500gb.
Installed in correctly at U8600 and U8700 following the PIN 87 in the schematics - but i do not get 2.5V output from the TPS62180.
Replaced U9000 just in case. Still the same.
Can you help me what i did wrong ?
