Macbook A2141 820-01700 No Response to Amp Meter
Instafixx
Hello,
I have a Macbook 820-01700 not turning on. No response to the AMP Meter as well.
But very dirty. Cleaned it.
PPBUS_G3H is shorted.
PPBUS_G3H_SSD_SNS shorted.
Where do i start?
What is the exact ohm value of that short?
Compare with the readings on all big coils.
Don't forget L9080/580...
Instafixx
Its 0 ohms - PPBUS_G3H
Getting 5V on PPDCIN_G3H.
R7021 — 1.00 Ω
R7022 — 1.00 Ω
R7061 — 1.00 Ω
R7062 — 1.00 Ω
All above are 1.2Ohms.
Should i replace the U7000 from a donor board ?
Don't touch U7000 yet.
Did you do what I said about the coils from secondary power supplies???
Remove F7000/1 and check which side the short remains.
Instafixx
L9080 and L9580 - Normal Diode Mode Readings are .395
Removed the FUSE. Short is at Pin #2 PPBUS_G3H.
Diode Mode Readings on Pin #1 is .480
What do you expect, if is connected to PPBUS_G3H???
I said to compare short value with the readings on all big coils to ground.
Instafixx
Red to Ground
L7030 .373 on Both Pins.
L7701 .183 on Both Pins
L8102 is .056 on Both Pins
L7660 is .304 on Both Pins
L8410 is .833 on Both Pins
You couldn't find all of them?
Where are the mentioned GPU and CPU coils readings???
GPU coils are hidden under black plastic, in the middle of the board.
Use boardview, please.
BTW, no need to check on both pins of a coil....
I said to compare with the reading on PPBUS_G3H side.
If no close reading value, then is safe to apply voltage injection method.
But you MUST be very sure have checked ALL coils.
And is not the case here. you still miss some of them!
Really, didn't see L3500, LB700, LA860/70, LA950, L7330, LA750, L7211, L7410???
Of course, check only ONE coil when you have more tied together...
Instafixx
What do you mean by comparing with PPBUS_G3H? i didnt get you. PPBUS_G3H is 0.001.
L3500 0.418
LB700 0.418
LA860/70 0.036
LA950 .056
LA850 0.073
LA750 0.006
LA7231 0.04
L7330 0.014
L7221 0.002
L7211 0.003
L7420 0.005
L7410 0.005
Instafixx
I have a 5A PSU only. Let me try and revert back. I have those resin smoke devices that help determining a heating component . Will try that if needed.
Instafixx
Found C6466 getting very hot. Replaced that. PPBUS is no longer short. Put Back the Fuses. Machine is ON. Thanks.
Instafixx
Hi Got another similar Case.
Here the PPBUS Short Value is 0.014.
All big coils reading are similar to what posted above.
Should we inject 1V
