MacBook A2141 820-01700
iFix
Hi.
I have this A2141 with a shorted SSD, and I found and replaced the SSD, only one of the chips was damaged, all else on the board is fine. Now I'm trying to restore it with DFU mode with another Mac (Apple Configurator 2), but I get an error. I'm not sure if the error is from the chip not being compatible, or maybe I need to write the data for it, which I can try with the P13 programmer from JCID. Any ideas, please?
The NAND must be initialized, according with its position on the board.
Not having short on other NANDs, doesn't mean they are good 100%...
What do you mean initialized, according to its position on the board? The Nand it's correctly positioned if that's what you mean. What do you suggest the next step?
I haven't done it but I can write the data with it and try, so we see if it will show an error again
I tried to read the new chip on the P13, at first it reads it, but then it said no chip, which is strange because I have tried those chips before and they worked
