Macbook A2159 No Camera
Instafixx
Display is broken and L8504 is missing. i do not have a donor board to replace it.
I have 820-02020 and 820-01700 and a bunch of 820-00165.
Can i use a part from these ? If yes can you specify the component number on the board ?
0.01-0.03mm enameled copper wire should be good enough.
Anyway L8504 is present on A2141 board too; use that, if you are afraid to bypass it.
