Macbook A2179 Only boots to Internet Recovery
Shantiche
I have a macbook that only boots to internet recovery. Option key doesn't change anything nor does Diagnostic key or safe mode.
Tried resetting PRAM still booted to internet recovery. SMC was reset as well. Still nothing.
Once continuing on with Internet Recovery it shows an error at the end 2005f or sometimes 2100
Tried Wifi at different locations on the island and it still gives an error code at the end.
Tried hard wiring using usb c to ethernet adapter. still boots to internet recovery error,
Whats next ?
From my notes:
Error 2003F in recovery mode, after DFU restore.
Start in boot menu and connect to wireless network.
Then press Command + R; it should continue the installation normally.
Check if helps in your case.
Shantiche
Getting the below Error when trying to Restore.
" The System cannot be restored on this device "
"Failed to copy auth install options in DFU mode"
'' ( com.apple.MobileDevice.MobileRestore-0xDAF (3505) )
My MacBook is running Monterey and Private relay is disabled
