The MacBook does not boot.
It is restored via DFU without errors.
The MacBook charges and consumes 20V/2A.
without battery the board consumes 20v\0.233a
The caps lock does not light up, but the touchpad clicks.
The fans do not rotate.
No signs of life
PPBUS_G3H=12v
PP3V3_G3H=3.38v
the macbook has not been used for a long time, which is why the battery has swollen and the mac did not charge and did not work. I replaced the battery, it started charging but did not turn on. I checked if it was in DFU and it was in recovery! It recovered without errors but does not show any signs of life. Without a battery, the consumption rises to 20v \ 0.570a and then sharply drops to 20v \ 0.230 and stays there! The board looks perfect, no one opened it before me, there are no traces of spillage inside, although it seems to me that liquid got on the keyboard, but everything is perfect inside
PM_PWRBTN_L do you mean PCH_PWRBTN_L ?
There is no PM_PWRBTN_L line on this board.
voltage 3.3v appears on lines PM_RSMRST_L, PCH_PWRBTN_L only when switching PMU_ONOFF_L
Yeah, PCH instead of PM...
You should note the drop pulse on PCH_PWRBTN_L, when trigger PMU_ONOFF_L repeatedly.
PM_RSMRST_L should stay high at same time.
when short-circuited to ground PMU_ONOFF_L voltage appears briefly:
PCH_PWRBTN_L =3.3v then 0.086v then 0.002v
PM_RSMRST_L=3.3v then 0v and does not remain high
