Macbook A2289 Shutting Off Immediately
Instafixx
No Corrosion.
Disconnect the trackpad and it stays on but it turns on on a weird screen. The screen shows - to connect a wireless apple mouse and keyboard (graphic images).
Tried another trackpad and another cable too.
What can be the issue?
Instafixx
With TP/KP connected. Won't go into Safe Mode.
Tried Command + R just to check. Stuck at boot loop apple logo..
Put it into DFU. It stays - checked for about 90 seconds
DFU Revive Gives this error.
The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xFFFFFFFFFFFFFFFF (-1) [sys = 0x3F, sub = 0xFFF, code = 0x3FFF (16383)]]
Tried with a different trackpad and cable as well. But its for A2338 - I don't think it matches.
Tried known good trackpad board/cable from same A2289 model?
Still stuck on network connection?
Tried external keyboard/trackpad?
"Disconnect the trackpad and it stays on but it turns on on a weird screen. The screen shows - to connect a wireless apple mouse and keyboard (graphic images)."
I was referring to this; not to DFU behavior...
Instafixx
tried restoring with a known good trackpad as well. Same -1 error.
I think board not detecting trackpad.
Shorted Lines
3v3_g3s_tpad
3V3_TPAD shorted too.
Injected 1V. Replaced the bad cap.
Still needed to replace the Trackpad as the old one doesn't work.
Issue Resolved . Installing NewOS
