Hello,
I have been working on a Macbook Pro A2289 board number 820-01987-A for the past few days. I have found this problem quite strange, and I can't see how to sort it out according to my knowledge.
The MacBook arrived with water damage. It was not too much, but it got to the board and affected some components on PP3V3_S5, I have replaced all the resistors with the according value, and the machine is taking 20v and 0.200 amps without the battery plugged in, with the battery taking 0.533 amps (battery is probably full), it does not make any power on chime the fan spins, it looks like it is on but not displaying anything, tested already with a known good screen,
I have also booted it to DFU mode. I tried to revive it, and it showed that it worked; after completing the process, it showed the locker square image, but there was still no display in the apple configurator the status was showing booted.
It is the same on the external screen.
All power rails are measured and good.
Is there any advice on what I should check to fix the issue?
I also have attached a photo with the components affected.
I really appreciate any help you can provide.
