Macbook A2337 (820-02016) PPBUS 1V
Instafixx
Machine not turning on.
AMP Meter stuck at 5V.
PPBUS_AON is 1V.
Diode Mode Reading to Ground is .511
No sign of corossion on the board.
Getting 5V on C5201.
R5261/62 is 1.3 Ohms
R5221 is 1.3 Ohms
R5222 is 31.2 kOhms.
Should we replace R5222 ?
Instafixx
PP5V_S2 is 0V and Diode Mode is 0.280
PP3v3_S2_UPC is 0.2V and 0.452
PP1v25_S2 is 0.03 and 0.290.
P5VS2_EN is Missing.
PPBUS_5VS2_VIN = PPBUS_AON.
Should we go for a DFU Revive.
Instafixx
Page 29. LDO of U7700
pp1v23_s2
ppvdd_pmu_ldo_prereg
pp1v06_s2sw_dram
pp0v8_s1
all are 0V. Should we check further ?
MPMU_VREF_ADC missing also?
If none of these LDOs is shorted (or very low resistance) to ground, then bad U8100.
Instafixx
Yes MPMU_VREF_ADC is missing too.
All have good diode mode readings.
Should we remove and re install or replace ?
Instafixx
Just posting LDO Diode Mode Readings again before ordering the PMIC.
3v8_AON_VDDMAIn is .172
PP1V5_VLDOINT_MPMU is .238
PP1V2_S2 is .353
PP3V3_S2_UPC is .465
MPMU_VREF_ADC is .586
PP1V8_AON_MPMU is .457
Are these okay. Should i order a PMIC
