Macbook A2337 Not turning on
Instafixx
Device came in for screen replacement. We check the OEM screen and installed it on this device and every thing was fine.
Now the device will not turn on and pulls 5V with very low amps.
Sometimes it goes up to 20 V with zero amps.
Ppbus is 12.2
Device not in dfu.
Pp3v8 vddmain is present
Pp5v_s2 absent with no shorts.
Thermal inspection show U7700 heating up at on point.
Instafixx
Upon further checking
PP5v_s2 is missing
P5Vs2_EN is also missing with no shorts.
PPBUS_P5VS2_VIN is consistent with PPBUS_AON
PP3V3_S2_UPC is present.
For a very brief time I found one c port making the amp meter reboot
Instafixx
Followed the slight heating at one corner of U7700 and found that PP0V805_S1_VDD_FIXED is shorted with diode reading of 0.004.
As per opneboard data the reading should be 0.240.
Should we inject 0.5V and see ?
Instafixx
Tried that. Nothing got hot.
Removed all the caps and resistors of this line .
Still the short is there.
Bad M1 chip ?
You can't get anything really hot.
Just look on IR camera where is the higher temperature.
Remove CPU heatsink first.
Instafixx
There is no place where there is high temperature . Heat sink is off.
Moreover all the caps and resistors of this line is off the board now. still a short exists.
