Macbook a2337 sound not working
Extreme
Hello, I got a MacBook air a2337 with liquid damage; the audio board was damaged, sort and no power, I removed the short, and then I got the MacBook back on
after this sound was gone. I decide to replace the audio board, but the sound is still not working. Speakers are ok.
The motherboard is not corroded or anything.
Any advice for me?
Thanks
Very likely M1 damaged by leakage from PPBUS_AON to some of its audio data lines.
Check diode mode to ground on RIO connector (page 50); compare with good board.
Do you get headphones sound?
Extreme
I found a line CODEC_WAKE_L going to U8100.
It looks like a small burn. I am right?
I do get headphones sound.
You should check and compare diode mode readings, as above explained.
I don't see other reason than the leakage, caused by liquid spill on audio board.
Similar failure has been detected on 01521 and 01958 boards.
