Macbook A2338 820-02020
Instafixx
Stuck at 5V drawing a constant 0.450Amps.
PPBUS at 7-8V.
I checked and found PP1v25_s2 to be 0.280 which I think is a little lower than usual.
PP3v8_AON is 3.7V
RN420/1/2/3 heating up. Resistance Across Pins is 8 Ohms.
R770C across Pins is 2.2Ohms.
Bad U7700 ?
These readings look good.
Multimeter probes ad 1-2 ohm normally.
Do you get U8100 LDOs?
Check CD3217 chips LDOs too; voltage and diode mode.
Replaced U7700. Device on now.
Got 2 cases including this in the last 1 week of A2338 stuck at 0.45V.
Both lead to U7700 .
