Macbook A2485 Drawing 5V No Amps
Instafixx
Removed the Fuse. PPBUS is .120 and PPBVAT is .453.
Is I shorted ? I injected voltage and not drawing any amps. (0.002)
I removed RD590 and PPVIN_P3V8AON jumped from 0.120 to 0.450 which is the correct range as per openboarddata. Hence I feel there is a short. How to proceed ?
Instafixx
FYI I found little green on one of the caps of the PP3V8_AONSPMU line. No shorts but still replaced it.
Removed both fuses and I get 12.35 on Pin 1 of the Fuses.
Problem is on the PPBUS side but sadly it is not pulling any amps. I went as high as 4V. Still no amp draw
Instafixx
I tried increasing and decreasing the voltage continuously to find a slight heat spike in one on the Audio ics.
Removed. Short Gone.
The ics in these are SN012776. Is it universal with TAS5770 of the M1 models ?
