Macbook A2681 820-02536
Instafixx
Device had no trackpad keyboard and will only boot on charger.
UT360 was shorted. Replaced. KP/TP is now working.
But the device doesn't seem to detect battery and will only work on charger.
Settings show battery not connected and not charging and the MacBook being stuck at 1% perennially.
I meant voltage level.
If R51B1 is soldered, BMU_CWL_DET_L is grounded.
That's good; just be sure SYS_DETECT_L has also 0V.
That should be 0V even with battery.
In fact, is what battery expects to be enabled.
You can force it shortin to ground, just in case.
Now check voltage and diode mode to ground at SCL/SDA lines pf battery bus.
