MacBook Air 13" 2011 820-3023-A Charging problems
arash
the magsafe doesn't light up and doesn't charge the battery except if you disconnect the battery once, any ideas?
arash
Hi, the center pin Voltage is 3,4 when Battery is disconnected. Battery Connected Voltage is 0,2 on Center pin and 6,6V on + Pins.
That does not make a lot of sense. I see no reason for the one wire to go to 0.2V when a battery is connected. Is ACOK signal staying high? Is PPBUS 8.6V without battery?
arash
Thats what I say, it doesn't make any Sense... but when the Battery is disconnected everything works fine, reconnect the battery charges the battery. Then disconnect the Magsafe and reconnect it there no charging activity. I will check the other voltages and give u a feedback.
