MacBook Air 15" A2941 820-03160 Stuck 5V 0.009-0.010A
BGTR
I have a MacBook Air 15" 2023 M2 A2941 820-02862 motherboard that won't power on. Initially, a malfunction was detected in U7700, which was replaced, and the diode values returned to normal. However, it's worth noting that the PPBUS_AON line has an abnormal value of 0.075V. I've already replaced U5200, but it continues to behave the same way.
Which schematic are you using?
"PPBUS_AON line has an abnormal value of 0.075V"
If that is voltage, what is diode mode to ground reading?
Remove battery + charger and wait 15s before checking.
The voltage at the PPBUS_AON diode is 0.012V.
I'm using XZZ's schematic. Although it lacks information, it gives me an idea for comparison with an A2681 board.
I don't see F5200 in A2941 because it seems to be the same line, PPBUS_AON and PPVBAT_AON_CHGR_REG. I'm not sure if I'm mistaken.
I tried applying voltage to the line, but it didn't heat any specific component. However, it did heat up part of the board.
Applying voltage without any previous checkings?
Do you have same 0.012 reading on any coil from secondary power supplies derived from PPBUS_AON?
I'm sorry, but I'm stuck on this.
And yes, all the secondary line coils have the same PPBUS_AON diode value.
Impossible to have the same readings on ALL secondary coils!
I don't have the correct schematic, but looking at 820-03286, did you really check (corresponding coils) L5800, LC320, LC710, etc?
Hi, I went on vacation for a couple of days.
Diode readings:
L5800: 0.340
LC320: 0.309
LC710: 0.485
Just in case, check at LP800 too.
If no low readings on secondary coils, then is safe to inject voltage on PPBUS_AON.
As always start with just 1V, increasing slowly and looking at the board with thermal camera.
Set amp limit to 3A, should be sufficient; also remove CPU heatsink.
0.012 is not pure short; may need to go up until 5V or more, to detect something on the IR camera.
Inspect audio amplifiers areas first; these are very sensitive to corrosion.
Do you have short to ground on that line?
Try to clean the hole, without damaging inside layers; may be impossible...
