I have a MaBook Air 820-3435-B it screen went black. I connected external monitor and there was no luck. PMU/SMC reset nothing changed. I removed the SSD rebooted no luck. after running some test on the board i found the flowing.
Q3080 pin 2 and 3 has almost no voltage 0.01x
L3095 same case there is no voltage.
Q3080 pin 1 and 3 getting 8.5 volts.
am i on the correct route ? what should i check or what could be the problem?
Thanks
Thanks
