Macbook Air 820-3437-b Doesn't turn on.
sh33pz
Hello,
The history with the MacBook Air is, the person was using on an airplane trip and it just died in their lap as they were using it.
When I received it, it did not have a light on the MagSafe(using an apple original charger, not a knockoff).
PPBUS_G3H had 8.19v, it should have been 8.6v which means SMC not talking to the ISL and it was missing the PP5V_S5 rail @c7505 as well.
I have swapped the SMC and now have the correct PPBUS_G3H 8.56v @f7140 both sides and have my PP5V_S5 @c7505 as well now.
MagSafe light does come on, green then turns to orange.
I have all of the correct voltages on the S5 rails.
I am missing PP5V_S4RS3 rail and turns out I am missing PM_SLP_S4_L.
When checking around the U0500 (system power management) IN lines:
@r5231 PCH_SUSACK_L 40mv
@r1995 PM_SYSRST_L 57mv
@r1962 PM_PCH_SYS_PWROK 0v
@r1963 PM_PCH_PWROK 0v
@r8133 PM_RSMRST_L 0v
@r1802 PM_PWRBTN_L 3.4v
@r5185 SMC_ADAPTER_EN 3.39v
@r1410 PM_BATLOW_L 3.32v
@r1450 PCH_DSWVRMEN 3.22v
@r1451 PM_DSW_PWRGD 3.42v
@r1452 PCIE_WAKE_L 3.32v
I have PPVRTC_G3H 3.32v @r1450 so I assume the u1900 chip is working.
The board has no corrosion on it at all and no liquid damge.
SMC chip did come from a donor board, so, maybe thinking in trying another?
I feel, I am missing something dumb and my brain isn't clicking at all.
What information can I get you?
Check if L7520 pulses at least.
Do you get 3V at PM_SLP_SUS_L?
If not, check all PCH's RTC signals.
Aso check 32KHz output from U1900.
sh33pz
L7520 0v both sides, no pulsing with the voltmeter.
@r1464 PM_SLP_SUS_L 0v
@r1301 PCH_INTRUDER_L 3.0v
@r1302 PCH_INTVRMEN 3.2v
@r1300 PCH_SRTCRST_L 3.3v
@r1303 RTC_RESET_L 3.3v
I have no oscilloscope to check for the 32KHz u1900 but took a DC volt reading:
Pin12: 440.2mV
PM_SLP_SUS_L should go high with these readings.
As it didn't, PCH is the suspect here, because it gets correct signals.
Use quality flux and heat PCH/CPU to 180-200 degrees, no more; just in case some crap under...
sh33pz
I did as you instructed and MacBook is now running. My question is since I reheated the PCH/CPU I am assuming this is more than likely a short-term fix and the CPU is on its way out?
