Macbook Air - Chime & Backlight works, No display...
Sykulski
You checked the board but you are not mentioning if you checked with another display. If not then start there. Don’t diagnose the board before you are 100% sure it is a board issue. It could also just be a bad lcd-cable. If you don’t have a known good display at hand then start with disconnecting internal display and see if an external one shows an image.
Sykulski
Don’t use comments as replies as they can easily be missed. First thing you did was it trying a known good display or was it to test with external screen while internal display disconnected ?
Is your board model 820-3115?
Do you get pure white or black display?
Check for knocked off components in the LCD connector area, both sides of the board.
Need to know if you have white screen or black with backlight on.
Remove the SSD and do a PRAM reset and see if you get a question mark.
