Macbook Air early 2015 13'' panicking and freezes.
Vertx
Hello, i have Macbook Air early 2015 13'' which recently started to freeze just after it boots and then restarts to repeat the process. Got a chance to get to the logs and take a photo, thinking it's CPU, what i could check or do? Sometimes even freezes at startup, maybe ME clean?
Yes, you should try BIOS; make backup and verify reading is good, before write new file.
Is that 820-4924 board?
Vertx
No, it's MacBook Air 13" A1466 early 2015. The thing is, i only have CH341A programmer atm, will look forward purchasing medusa 3, but working with CH341A, MB 2015 efi don't have any legs so i assume i need to solder chip directly to programmer? And last question i need to clean ME or to reprogram with new bios?
Try first cleaning ME.
You can solder WSON8 chip on a normal SOP8-DIP8 adapter, taping middle part of the pads with kapton tape.
Somerhing like in these pictures.
Vertx
Before cleaning ME tried different ssd with installed OS, machine boots fine, even after some usage, few restarts, but if i'm trying to boot to any mac os installer usb it freezes on logo ar start, so think it might be defo bios issue. Will try to clean ME, thank you.
