macbook air Logic Board 820-3437-B FA turning on issue
mobajer
Hello, I have Logic Board 820-3437 board, which looks like new, no water damage. But sometimes refuses to turn on. But if turned, fully works. Thanks for advices.
mobajer
everything disconnected, only charger, green light goes to orange and cooler don't start spinning. PPBUS_G3H is 8.6v, SMC_ONOFF_L is 3.4v. short to ground SMC_ONOFF_L but nothing happens.
If there is no liquid present then this one is going to suck. Sometimes there is corrosion around U1900 and the traces to Y1905. Intermittent issue are pretty hopeless
What good will that do? It turns on sometimes so finding such an intermittent issue is a nightmare. I gave you something to check. If that is ok then it can be anything and probably going to be a no fix.
mobajer
OK, throw this away.
have 820-00165 no water, clean as new. battery chargers, but no way to turn it on. if connect only charger green light changes to orange and thats it.
PPBUS_G3H 8.6v
SMC_ONOFF_L 3.4v
what voltages should I check next? what further steps. thank you
