macbook air no sound
sisyphe
hello
could i have some help to understand where is my mistake, anyway still don't know how the sound are generate in appleboard
this board macbook air "Core 2 Duo" 2.13 13" (Mid-09)
it been back to life with reflow but it's for me a nice training that's the point
the wire who connect the FaceTime camera was cut off and L9050 and C9050 been damage did replace them, FaceTime working no sound or mic
i connect the mac on cinema display it has sound and mic then not GPU problem !
PPBUS_G3H i have 7.46V
PP3V3_S0_MIC_F is 3.3V sorry
I think it could be a transistor gate how to check it ? show me the way please
i have another board then i got all SMD needed !
please don't tell me it's a IC
thank you so much
Post 820-xxxx of your board.
Need to know which schematic to use...
Bad audio connector is common failure for all MacBooks; as broken traces, or small resistors/coils on its area too.
sisyphe
holla
820-2375-A and i do use the schem MLB M96 PVT 09/26/2008 and 820-2375.brd
audio connector look good
will test all the traces , i'm back to say if this it
gracias por su ayuda
Alan.L
measure voltage on PPBUS_G3H (PPVIN_S0_AUDIO) on the audio connector.
sisyphe
hello
PPBUS_G3H on the audio connector IS 7.49V not good (it should be 12.6V )
no sound at all ! by the macbook it self , but connected to cinema display every thing working true the mini display port
can't found this PPVIN_S0_AUDIO on schematic !
PPBUS_G3H have 7.46V
PP3V3_S0_MIC_F is 3.3V sorry young and confuse
( if i understand well it could be U7900 IC ? CHGR_UGATE 7.51V / CHGR_LGATE 0V / CHGR_PHASE 7.48 )
really appreciate
Alan.L
board was it liquid damaged? when you goto system preferences > sound > does it show any sound output?
have you try another audio board?
i think display port use MCP for sound and internal speaker use audio board for sound.
sisyphe
not liquid damaged and no was all greyed ou no sound output or input Yes i did try another audio board and speaker
ok working thank you it was faulty flex between mainboard and speaker
really appreciate your help anyway i learned see you soon !
