Macbook Pro 13" Early 2011, cannot install High Sierra
VinceLx2
This Macbook is working fine, ASD 3S144 showed no issues.
I tried to install High Sierra, but the installation stopped and I came back to the initial installation menu.
Then I managed to install El Capitan, it updated the BIOS during the installation. I downloaded an update from Apple, and it did another BIOS update.
I tried again to install High Sierra, this time the installation went deeper (I saw the progress bar with the countdown), and it finally crashes. I saved the report, see attached, in case it can help, also 2 photos attached.
What can I try to solve this? Flashing a new BIOS?
The SSD is brand new.
  • Registo do Instalador 10-Mar-2023.txt
Try one RAM module at a time.
Also try changing SSD flex.
Just in case, check if it let you install High Sierra into USB pendrive/SSD.
VinceLx2
I tried one different memory module, same issue.
Then I tried to install on an external SSD drive, but this time the installer window (with the choices to Restore, Install, Disk Utility) did not even appear and the computer restarted, and I finally got the grey screen : "Your computer restarted because of a problem".
