Hardwood T/S
Got a Mid-2015 15" retina board here, everything works fine except for the backlight on the screen. LVDS connector had corrosion on pins 2/3/4, LVDS cable had corrosion similarly on both LB and screen side in the same areas. Connector cleaned nicely, but the LVDS cable had pin 1 basically broken off of the plastic that holds it, along with the plastic itself. Decided to swap the cable with a known good one, but after inserting and seeing the same issue, I removed it and found it also now had it's LVDS cable's pin 1 broken off with the plastic.
Spitballing, but seems like this connector needs replacing, yes? Every cable I put in has it's end chewed off by something inside--can't get a good enough look with my microscope lenses. The connector itself looks fine on it's pins connected to the LB after cleaning, but it'd be good to replace it anyway.
I'm not sure what I'm supposed to be reading on the capacitors connected to pins 3/4, I don't have the boardview or schematic right now, but they look off--both diode mode and resistance mode show endlessly climbing values.
