Eniaro
Hi Noob here kinda I have a MacBook Pro 2019 A2159 (2-port) wont boot
Trackpad clicks.
Plugging in a genuine USB-C charger and any other charger = 20V and charges all the way.
Plugging in a Dell USB-C dock (WD15 docking station: is capable of outputting 19.5V/3.34A)
or
Dell USB-C monitor causes the voltage to cycle endlessly between 5V and 19V (Dell P2419HC: has built-in power delivery, capable of outputting 20V/3.25A)
The Caps Lock button doesn't illuminate.
Holding the power button (fingerprint scanner) for 10 seconds stops the trackpad clicking temporarily, but it starts clicking again after 3 seconds.
If I open the lid slightly, the trackpad stops clicking.
The keyboard backlight is not working.
The Touch Bar is not displaying anything.
Resetting the SMC and PRAM, as well as fully discharging the battery, has not resolved the issue.
I've replaced the display. ( Original had a small crack on lower right corner)
I've even bench-tested the logic board with nothing attached, plugging in a genuine USB-C charger and any other charger = 20V but the same 5/19V loop cycle when connected to a USB-C hub or monitor.
No physical components are visually damaged
I'm at a loss as to where to start troubleshooting this problem any help will be appreciated
Trackpad clicks.
or
