Macbook Pro 820-00239 short PPVCC_S0_CPU
Tarek
i have a short on PPVCC_S0_CPU (no damage liquid).
where i can inject volt on which capacitor or coil ?
what maximum voltage ?
Thanks.
What is the exact ohm value?
Compare with good board.
CPU coils have very low values as normal; depending by CPU type, of course.
Tarek
I don't have a good board for check.
I have un short on C10G0 (continuity mode)
I remove C10G0 for check , but I have a short
I need to inject volt ?
Tarek
Sorry for the late, diode mode probe red on ground
L7210 (mode diode) 0.011 , value ohm 16.9 ohm
L7220 (mode diode) 0.011 , value ohm 17 ohm
L7270 (mode diode) 0.017 , value ohm 23.4 ohm
L8050 (mode diode) 0.043 , value ohm 60.2 ohm
thanks
I don't know why I got confused, thinking is 00045 thread.
So, L7410-30 exist on your 00239 board; there is iGPU power rail.
But you don't want to post ohm resistance to groud.
About C10G0, you've said to have 17 ohm at CPU core power rail; explained as being good value.
No idea why do you insist about a short there...
