Vogelek23
Hello,
Currently working on the one from topic title with no audio device issue (originally won't boot).
First of all, tried known working OS - no luck. Checked MLB under microscope and found that U6400 looks strange - measured it and power bus was shorted to ground so I have removed U6400. I spotted underneath that someone has attempted to make some "unsuccessful" work here, found ripped off C5 pad (NC) and a bit corroded D5 pad (AUD_SPKRAMP_INT_L). Removed the signs of corrosion and tested MLB - still no audio device present. Replaced U6200 and R6228 (this resistor looked like overheated and had only 20 Ohms despite it is 33 Ohms). Neext I found AUD_SPKRAMP_RESET_L and HDA_RST_L to be High, power rails for U6200 correct. R6203 - 0V and no oscillograms on both pins, value 33 Ohm, 540mV on diode test (red probe to resistor, black to GND), shouldn't be some data visible over here?
My main question: should U6400 be assembled to get the audio device visible in the OS? If not, what is the next step in diagnosing of such problem?
