Macbook Pro A1708 (820-00840-A) Random Death
GadgetsFixLeeds
Hello, I have a pro A1708 that's unresponsive, the fan spins for a few seconds if I disconnect and connect the battery and the Amp pull keeps going up gradually 0.8-3.0, it seems dead but the trackpad vibrates when touch, 13v present on L7030, both 'CD3215COO' as well as the SSD get warm after a good few minutes. Any help would be appreciated, Thanks in advance.
GadgetsFixLeeds
Hi, these are the readings
L7670-- 5.1V
L7690--3.31V
L8410--0V
L7030--13.07V
L7730--1.0V
L7430--0V
L7410--0V
L7420--0V
L7210--0V
L7220--0V
L7370--0V
L8060--1V
L7900--1V
L7960--0.95V
L8030--1.1V
Post resistance to ground at L7370 (ohm scale).
Also check R/C7379 and R7376.
If all OK, try known good BIOS...
L7370 voltage must appear before L7210/20.
But all of them are controlled by same chip, U7100.
These voltages depends by BIOS, U7100 and PCH/CPU.
Very likely bad CPU.
Did you test the board alone on the desk?
No SSD, nor LCD, or other devices; only charger connetced.
GadgetsFixLeeds
I have similar issue with another A1708 same board number, only one USB-C port was working, I replaced the port and now it does the same thing, Fan runs once when I reconnect the battery and the CPU and SSD warm up a bit but no display at all
Stop considering the video as the only life sign.
Always check final CPU core voltage on these A1708 boards.
Also USB activity is a must check ALWAYS.
About the second board, if was working before touching USB-C area, CPU core voltage appears now?
I suppose something was affected by the heat applied on that board...
Board can't boot without CPU core voltage.
Check voltage on other big coils; of the second board.
For the future, open separate thread for different boards; even if the same models.
