Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A [solved]
datatech85
Hello,
I am working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
The Macbook consumes 5V and 0.019A at USB-C.
I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
However, I can't work out exactly why I don't have the PPBUS_G3H rail.
Here are the values I measured:
PPBUS_G3H: Diode = 0.006 / Resistance to ground = 6.7 ohm
PP20V_USBC_XB_VBUS = 5V
PP3V3_UPC_XB_LDO = 3.3V
PP1V8_UPC_XB/XA/TB/TA_LDOA = 1.8V
PP1V8_UPC_XB/XA/TB/TA_LDOD = 1.8V
PP1V1_UPC_XB_LDO_BMC = 0V
PPDCIN_G3H = 5V
SMBUS_SMC_4_G3H_SDA = 0V
PP3V3_G3H_RTC_X = 0V /Diode = 0.4 / Resistance to ground = 800kOhm
There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail and low resistance.
I noticed that the RB703 and RB731 resistors have lower values than expected: RB703 = 7.3kOhm and RB731 = 16kOhm (instead of 27.4kOhm).
I've tried injecting 1.0V on the PPBUS_G3H rail but nothing heats up and it draws 0.330 Amps maximum.
Don't hesitate to ask me if you need any further information. Thanks in advance!
Aprox 6 ohm to ground doesn't sink to much current from 1V.
Difficult to detect anything heating with fingers only; IR camera is recommended.
I don't recommend to increase the voltage directly.
Check first if any big coil gets the same reading to ground.
Don't forget L9080/580.
Then we decide if you need to increase injected voltage, or the problem resides into a secondary power rail.
datatech85
Thanks for your quick reply!
I've used a thermal camera to detect a component that's heating up, but I can't find anything that's heating up.
I have big coil near the CPU that gets the same reading to ground (L7420 and L7410)
L9080 seems good as the resistance value starts at 1 mega Ohm and gradually decreases towards 180 kilo Ohm.
Thanks,
datatech85
I get 0 ohm between these 2 coils : L7410 & L7420 and PPBUS_G3H. Does it mean there is fried component between PPBUS_G3H and CPUGT ?
datatech85
It's done, I removed U7410 and I have a resistance value between coils L7420/7410 and PPBUS_G3H that increases progressively until infinity! What's more, I no longer have a short-circuit between PPBUS_G3H and the ground :D
Would you advise me to put in a new chip, re-solder the fuses F7000/F7001 and test to see if it works? Or do I need to run more tests to make sure everything's OK?
