MacBook Pro A2141 820-01700 dead SSD
ielectron
Hello,
I am wondering is it possible to replace SSD IC's on this boards or they linked to the components on the board like an iPhone memory? If it is possible would be a donor board where I should look for this NAND IC's ?
The U9580 was liquid damaged and SSD lines PP2V5 are shorted to the ground, short check showing NAND are dead warming up when 2 V injected to this line
Thanks for help
Yes, you can replace them.
You can buy complete kit on Aliexpress, already initialized.
Also can get them from donor board, not the same model.
01041 and other models can serve for this purpose.
Be aware to place them in the same sequence.
If your board has 5 NAND chips, need to remove and left empty the 5th one.
Be aware of actual SSD size configuration of your machine, to get the correct replacement NANDs.
