Macbook pro A2289 820-01987 liquid damage 5V 0.10A
Vertx
Hello!, have macbook pro A2289 820-01987 which had liquid damage. Replaced damaged and corroded components, device gets 5V 0.10A. Device is detected in DFU mode, tried to revive it but got an error. What could i check next please?
PPBUS_G3H 12.27V
3V3_G3H_RTC 3.3V
PP3V3_G3H 3.3V
Corrosion on the backlight circuit is very bad.
Leakage to data lines can easy kill T2, or CPU.
Do you put the machine in DFU with keys combination, or it automatically appears in AC2?
Check diode mode to ground on all coils; including the small ones for SSD.
Compare readings with good board.
Vertx
It automatically appears in AC2. Don't have same working board at the moment to compare, but i will check them as soon as i will have one :giggle:
