No-Clean
Hi all,
First post here, Im a newbie starting up on board level repair so take it easy
ASD fails with error code -- 255 (Check that CPU heatsink is properly attached, using product spec theta dh + 75 percent guard band.
The heatsink had some green corrosion that I was able to clean, it was not bent and no physical damage.
I cleaned the CPU and put new paste that I have here but Im sure it is not the same as what that theta dh = 75.
I also replaced C5702 as it had no voltage and looked pretty bad, but so far same problem.
I am thinking about ordering a new heatsink, but my gut tells me that is not the problem, however Im hungry so I cannot trust my gut right now :=)
This started to happen after update.
