Mikyjordan
Hello everyone,
I'm new to the forum, and I've heard great things about this community, so I decided to join, hoping you can help me.
The story of this Mac is a bit complicated. Let me explain step by step:
Here are my measurements:
Thank you all for your support. I hope to make my customer happy. I look forward to your advice and suggestions for further tests.
P.S.: Apologies for my English—I'm Italian, and this text was translated using ChatGPT.
- The customer brought me a Mac that wouldn't turn on. Using a USB tester, I measured 0V and found the CB300 shorted. I replaced it, and the Mac powered up again.
- The computer works only with external power, not with the battery. It charges the battery correctly, but if I disconnect the external power, it shuts off.
- Unfortunately (my mistake), while performing some measurements, I short-circuited a component (see attached photo) and possibly something else. As a result, the ISL (U7000) burned out, and the Mac got stuck at 5V.
- I ordered two ISL chips from AliExpress and soldered both. However, a new issue arose: the Mac works on battery power but not with external power. The USB tester correctly detects 20V, and the Mac recognizes that external power is connected, but it doesn't charge the battery.
- This issue occurs with both ISL chips (I’d like to rule out that both are defective). Specifically, the Mac powers on normally with the battery installed, but not with external power alone.
- If I remove the battery, the USB tester shows current oscillation between 0.020 and 0.180 mA. When I connect the battery, the USB tester oscillates between 0.000 and 0.008 mA.
- PPVIN_G3H_P3V3G3H: 21V
- PP3V3_G3H: 3.2V
