managerharry
MBP 820-3662 board. It had a bad battery and would only run off AC power but was otherwise OK. Also checked the logic board and found a small amount of liquid damage near DC in board (C8324 & surrounding), and a bit more under the tape at C7372 and C7378, and the CPU screw mount next to C1099 had popped off the board. Cleaned up corrosion and epoxied CPU screw mount. Popped replacement battery in and.... fuck, it powers on and fans spin for about 5 seconds, spin down, then spin back up and it stays on but does not post, no chime. Plugging in USB mouse shows only brief flash of light when USB is first plugged in. SMC reset done using internal kb does result in charging light change blink as per normal but otherwise has no effect. CAPS lock light does not respond. CPU gets warm after 5-10 min, but not particularly hot. Attempting to power on in SMC bypass results in hurricane mode fans but no post. Genuine MagSafe 2 charger.
Some readings:
PPBUS_G3H = 12.68
PPVRTC_G3H = 3.36
PP5V_S5 = 5.09
PP5V_S4 = 5.09
PP5V_S3 = 5.09
PP5V_S0 = 5.09
PP3V3_S5 = 3.36
PP1V5_S0 = 1.52
ALL_SYS_PWRGD = 3.24
PLT_RST_BUF_L = 3.35
PPVCC_S0_CPU = 1.71
PP1V35_S3RS0_CPUDDR (pin 1 of C1099) = 1.37
Smc_bc_acok = .85
CPU toast or is there hope?
Some readings:
PPBUS_G3H = 12.68
PPVRTC_G3H = 3.36
PP5V_S5 = 5.09
PP5V_S4 = 5.09
PP5V_S3 = 5.09
PP5V_S0 = 5.09
PP3V3_S5 = 3.36
PP1V5_S0 = 1.52
PPVCC_S0_CPU = 1.71
Smc_bc_acok = .85
