missing pm_slp_s4_L 820-3476
shanenin
I am working through a missing pm_slp_s4_L on an 820-3476. The board appears clean.
here are the following readings
PPVRTC_G3H : 3.3v
PM_SYSRST_L :1.9v LOW?
PM_PCH_PWROK: MISSING
PM_RSMRST_L: 3.3v
PM_PWRBTN_L: 3.3v
SMC_ADAPTER_EN: 3.3v
PM_BATLOW_L: 3.3v
One of the issues seems to be PM_SYSRST_L is only 1.9v. That line is powered by PP3V3_S0, which is also 1.9v.
I am missing my P3V3S0_EN to turn on u8030 which produces my needed PP3V3_S0.
To produce P3V3S0_EN I need PM_SLP_S3_L which is 0v. Now I am unsure where that gets produced or maybe my logic is just way off on this whole path I am following. Thanks for any help. Shane
edit added later//
I did replace u8030, along with u1900, u1950
You cannot pursuit PM_SLP_S3_L before getting PM_SLP_S4_L.
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time).
shanenin
Thanks. I am assuming trigger must mean short to ground. Can I check for a drop pulse by just holding a voltage meter on PM_PWRBTN_L?
can I ask another question? how come I have 1.9volts on pp3v3_s0? Is that even possible without PM_SLP_S4_L?
"I am assuming trigger must mean short to ground."
More information available here:
"how come I have 1.9volts on pp3v3_s0?"
Don't waste time with that...
Do not quote an entire post, visible few centimeters above.
Write directly into Reply box, instead of clicking Reply button.
Please, mainatain forum aesthetic.
It means that SMC correctly sends out to PCH the power button signal.
Now check if PM_SLP_S4_L pulses at same time.
shanenin
Check PM_DSW_PWRGD, PCH_DSWVRMEN and the 4 RTC signals.
3.4 and 3.2 for the first two. I am not sure what 4 signals you are referring to. I am guessing this is to do with u1900 (I did swap it prior).
I am getting 32.7khz on pin 12 of u1900
"I am not sure what 4 signals you are referring to"
Read this...
RTC clock (32KHz) is provided externally to PCH.
It has internal RTC clock generator, but Apple doesn't use it...
