RESQ-MYTECH
Hi all, greetings from the UK... again. Now i am a little lost with this... nothing unusual.
MBP A1297 820-2914-A. Red bull definatly did not give it wiings. Keyboard naffed. Green LED on magsafe. No power. Motherboard surprisingly clean and dry. no corrosion visible across the board even under the scope. The was sticky residue on pins 1-4 of the LVDS connector, cleaned with flux and touched up with new solder. Still no power. Removed the board and started testing the power rails.... this is what I have so far:-
PPBUS_G3H 12.57V
PPVIN_S5_HS_COMPUTER_ISNS 12.57V
PPVIN_S5_H3_OTHER_ISNS 12.57V
PPDCIN_G3H 17.04V
PP3V42_G3H 3.48V
PPVRTC_G3H 3.323V
PP5V_S5 UNABLE TO LOCATE ON THE "NET" COMMAND
PP5V_S3 0.0V
PP5V_S3_ISNS_R 0.0V
PP5V-S0 0.0V
and following down the list of power rails becomes obvious the board is devoid of 5v
Now looking at the board view there is listed components in the location UD300 where going by the schematic I have should be 5v points. there is not a single component there. Not unduly worried as there is o solder there either.
Maybe I have gone letter blind but I can seem to find on the schematic the first instance of where 5v feed should be. I have gone away, had a cup of tea, come back and still unable to located where 5v first emerges. Would anyone be king enough to point me to where or what produces the 5v
PPBUS_G3H 12.57V
PPDCIN_G3H 17.04V
PP3V42_G3H 3.48V
PPVRTC_G3H 3.323V
PP5V_S3 0.0V
PP5V_S3_ISNS_R 0.0V
PP5V-S0 0.0V
