No backlight when battery connected
I have a MacBook Air 13" A1466 820-3209-A
There was corrossion under the backlight driver U9701 and no backlight. I changed the chip with a new one and now I get backlight but only if the battery is disconnected.
If I attached the battery I don't get backlight but I do get image.
Thanks in advance
Do PRAM reset first.
Post D7701 voltages, when no backlight present.
Also check SMC_LID signal, at same time.
Test what happens, if LIO flex is disconnected.
Yes, D9701; I was looking at 00165 schematic, by error.
SMC_LID must be high.
Check it disconnecting trackpad flex.
If still low, check R5071 value and traces.
My mistake I measuring at the wrong place. Yes SMC_LID is high and steady at 3.40v both when backlight works and when it doesnt. Is it possible the replacement backlight driver was bad or got damaged whilst I was heating it? Also it's ok to buy these chips off eBay right, I mean they are not programmed diffrently than ones off donor boards?
New chip is OK to buy.
I suppose you didn't get good solders.
Reflow it and try to solder U9701 properly.
You won't believe this but the chip I used for U9701 was wrong. Replaced with the correct chip and all is good now. Thanks again for your help - appreciated.
