Pinout of Home Button Connector? iPad 8 Wifi, torn pads A2270
Cire3
I have a iPad 8th gen, A2270 and some monster pulled a few pads off trying to replace home button zif connector. I started scraping to see if I can follow the traces. They are not clearly seen through the mask like I see some show.
Didn't want to start tearing all the mask off, and figure someone has seen this. Do we know where these traces go to ? Does it even use all the traces? iPad 8 seems to be the only ipad I don't have info on. Here is a pic of what I have under the microscope.
Cire3
Thanks for sending what you can. I have nothing to find the other end. I would like to fix the traces as it seems easiest (I would imagine anyway)
I just don't see what direction they go, or where they end up?
Cire3
Oddly enough, the pads that lifted are not used. The half pads I was able to use and were still connected. I believe I'm good, I'll assembly and test. Purchased ZXW to confirm pin location to components. They ohm out, so I may just have lucked out being able to repair. I'll double check with what you sent.
Again thanks !
