Power Supply Q
Absolute
Bought a Tekpower TP3005T https://www.amazon.com/Tekpower-TP3005T-Variable-Linear-Supply/dp/B00ZBCLJSY
Trying to hookup the leads to find a short onboard using constant voltage/constant current mode. Runs a fan or lights that I hookup to it successfully but when I hook the negative to ground and the positive to ppbus g3h p.rail the power supply drops voltage from the 12.5v I preset it to 0.00v and blasts the max amperage I set which is 5.2amp once I attach it to the shorted rail. Do I need a better power supply, ie. agilent or am I missing something. Sorry for the noob question but I'm beating my head against the wall
It's a dead short so of course the voltage will drop to 0 and max out the current. Something must be heating up now on the board for sure.
LearningMan
Bought a Tekpower TP3005T https://www.amazon.com/Tekpower-TP30.../dp/B00ZBCLJSY
Look up foldback circuits and crowbar circuits and you'll get an idea of why it drops the voltage.
Voltage will drop anyway if there is a dead short because there is a 0 impedance path to ground.
You don't need a better PSU. You can make your own to do the exact same job (for your purposes) for about £15. LM317 a couple resistors / caps and a crappy eBay LED panel volt meter.
