pp1v8_slps2r is missing on 820-01958
It had a dead short to ground at c7804 which is pp3v3_g3h_pmu_vddmain. I injected 3 volts to find it. now pp1v8_slps2r is 0v. do i need to replace to capacitor or no?
Board should start without it.
However, I recommend to solder another cap, once you get the board working.
could the usb-c ribbon cause pp3v3_g3h to fluctuate? the rail shorted again and had the replace q7680. now pp3v3_g3h fluctuates sporadically from 2.0v to 3.1v. could this be a ribbon issue?
the 3v3_g3h rail became stable but then after running the configurator i started getting 6.8 volts on 3v3_g3h afterwards . i get 3.3v without u7650 on the board and 20v on the amp meter. how is this possible without u7650 on the board?
Did you apply power without U7650, but Q7660/80 soldered on the board???
You are very lucky if none of them got burnt.
Do NOT do that again ever in your life!!!
Did you check all above mentioned?
Is the board still booting?
no it doesn't boot. u7800 was shorting the 3v3_g3h rail and was removed. Does the u7800 have to be there for 3v3_g3h to work?
i checked the circuit and it's just not producing 3v3_g3h. i don't want to put on a new PMIC until i get that rail working. do you know where i can get a new tps51980b?
Be sure to use TPS51980B there; NOT the A version.
On this board 3V3_G3H enable input is left floating.
All other boards where TPS51980A is specified, enable signal is driven high to enable it.
