Hello macbook repair experts, maybe this is a dumb question, but on many macbook repair youtube videos, especially from Paul Daniels, I have noticed that voltage is always 18V. I can see that in addition to USB Chipmunk tester, one important indicator is current that board is drawing. But if nominal voltage from the original charger is 14.85V (also written at the back of Macbook Air A1466 for example), so it could be possible to use 18V without problem, but in that case, current is not a reference, because boards draw power, so, if input voltage is higher, it will draw less current. On the other hadn, on Rossmann's wiki, there are exact values of current that points to different faults.
So, is it safe to use higher voltages such as 18V even if original charger is only 14.85V? So in these cases, actual current that boards are drawing are less than specified in the wiki table. Is this correct?
